May 25, 2023 at 7:30 am
SolutionParticipant1. Create 2 designs with desired differences (materials etc.) and link the meshes to make sure that the meshes are equal in both of the designs. This can be done by going to the solver setup of the second design, select tab Solver, tick ‘Import Mesh’, and setup a link to the first design. On the General tab change the ‘Maximum Number of Passes’ to 1. 2. Analyze both designs 3. Export the desired fields using Fields Calculator in both designs. For example Input > Quantity > B Vector > Mag Output > Write > B_steel.fld/B_iron.fld 4. Import the exported fields, subtract them form each other, and Create a Named Expression. For example Input > Read > B_steel.fld Input > Read > B_iron.fld General > – Add > B_diff > OK 5. Plot the differential field by selecting all the objects > right mouse button > Fields > Named Expressions > B_diff
1. 2046348.zip
- Cloud Computing from Electronics Desktop
- How to import/export an Ansys Maxwell model in Workbench?
- How to enable GPU acceleration in Electronics Desktop?
- Electric Motor Design Using Ansys Motor-CAD – Part 1
- How to fix messed up Windows layout?
- What are the available boundary conditions in Maxwell?
- How do I calculate inductance and resistance of a coil in post-processing phase?
- How to create and manage a queue of simulations?
- ANSYS Electronics Desktop: Simple Communications Channel For Signal Integrity Analyses – Part III
- Are solid losses and eddy losses the same in Maxwell?
