March 17, 2023 at 1:11 pm
SolutionParticipantBy default, a wall will have a thickness of zero; however, by specifying a non-zero wall thickness, a thin layer of material can be modeled on the wall. The thermal resistance of the thin wall is determined by the specified Wall Thickness, as well as the selected material in the Material Name drop down menu. This ‘Thin Wall’ feature can be used to model, for example, a thin piece of sheet metal between two fluid regions, a coating applied over a solid, or modelling contact resistance between two solid regions. Please refer to the attached PDF file for information on applying thermal boundary conditions to thin walls.
1. 2042850.pdf
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- How to add comments to journal file so that I will know what each entry does?
