June 5, 2023 at 7:05 am
FAQParticipantIn CFD-Post, the heat flux is provided at walls & interfaces only. As a workaround, it can be re-computed. 1. Re-compute the temperature gradient in CFD Post: New Variable –> Method: Gradient –> Gradient of: Temperature. It will be named Temperature.Gradient (in the category User Defined) 2. Create three expressions for the individual components myqx = Temperature.Gradient X * Thermal Conductivity myqy = Temperature.Gradient Y * Thermal Conductivity myqz = Temperature.Gradient Z * Thermal Conductivity 3. Create ‘myheatflux’ New Variable –> method: Expressions –> Vector –> use the expressions defined before
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
