Tagged: designmodeler, fluid-dynamics, General, Other, Preprocessing: Geometry
March 17, 2023 at 8:58 am
FAQParticipantYou can create a fillet in sketching mode. The fillet can be drawn for intersecting and non-intersecting edges. Select an endpoint connecting two edges, or two edges or points to place a tangent arc of the specified radius between them. You can create a blend and chamfer using Create -> Fixed/Variable Radius Blend and Create -> Chamfer tools respectively.
- Skewness in ANSYS Meshing
