Tagged: 18.2, BCs & Interfaces, compressible-flow, fluent, fluid-dynamics, materials
January 25, 2023 at 7:16 am
FAQParticipantR410a is only for inviscid flows since it does not have the viscosity definition. So R410a.ppf cannot be directly used. The workaround is to model R410a as a mixture of R32/R125 50% by mass, as both these materials are included in the database.
- Skewness in ANSYS Meshing
