June 5, 2023 at 7:04 am
FAQParticipantUnder Mesh object there is an “Inflation” tool which are mostly used for CFD cases to improve mesh quality at high stress regions. It can also be applied in Mechanical to improve mesh. For example to improve contact result, “inflation” can be used to mesh the contact surface with hexahedral elements through a specified number of layers and transition to tetrahedral elements.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- ANSYS Mechanical: Node Move
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
