How to use diagnostic tools to investigate import or surface mesh quality issues in Fluent Meshing Watertight (WTM) Workflow ?
Tagged: 2020 R2, FLUENT Meshing/Tgrid, fluid-dynamics, Watertight, Workflows
March 17, 2023 at 1:10 pm
SolutionParticipantWTM in Fluent Meshing enables users to generate good quality mesh on complex watertight geometry in a simple workflow. It is possible however that for the most complex models the surface mesh generation fails due to CAD issues or surface mesh quality. When this happens it is very useful to investigate the source of the failure with the Diagnostics Tools from the Outline View. Diagnostics Tools enable to mark different types of problems (free edges, bad skewness…) and zoom on their localisations.
1. 2063816.pdf
- Skewness in ANSYS Meshing
