June 6, 2022 at 9:30 am
Watch & LearnParticipantSee how to use the newest features of ANSYS Workbench Meshing to mesh thin surfaces (or shells) as well how to modify the mesh by direct interaction with the Graphical User Interface. This video show an example of a section of an automotive body in white geometry.
To discover all the other new features of ANSYS release 16.0, visit http://goo.gl/KDtc5d
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- What is the difference between shell 63 and shell 181?
- How to change begin node and element number for meshing in Workbench Mechanical?
