Tagged: 19, fluent, fluid-dynamics, General - FLUENT, workbench
May 15, 2023 at 8:32 am
Solution
ParticipantInterpolation files for Fluent results are written by default when working with Fluent in Workbench. They are used to speed-up subsequent simulations when working with multiple design points for the same component or analysis system. You can also use interpolation files to transfer the results when working with multiple component systems.
1. 2054519.pdf
2. 2054519.zip
- Skewness in ANSYS Meshing
