How to use an internal region for dynamic mesh when using Fluent in the System Coupling environment?
January 25, 2023 at 7:16 am
FAQ
ParticipantSet the internal region to be a porous jump. Then the internal can be used in the same way as a wall boundary condition for transferring mesh displacement via system coupling to Fluent. Even if Mechanical has no wall to directly transfer a motion, the motion of the nearest node in Mechanical will be applied to the mesh nodes in Fluent. Key word: system coupling; dynamic mesh; mesh morphing; internal; interior; porous jump, mechanical
- Skewness in ANSYS Meshing
