Tagged: 19.2, fluent, fluent-post-processing, fluid-dynamics, post-processing
April 13, 2023 at 7:33 am
SolutionParticipantAfter creating an iso-surface it is not possible to update the value or review the definition using the man page post-processing surfaces panel. However, you can use the scene description panel that you can open from the ribbon: Viewing > Graphics > Compose to update the value and get an idea about the original definition. The attached document describes the necessary steps for Fluent 19.2 and earlier. For Fluent 2019 R1 you can edit the surfaces directly.
1. 2056930.pdf
- Skewness in ANSYS Meshing
