June 6, 2022 at 8:33 am
FAQParticipantUnder Boundary > Intersect, there is a “Mark” button on the panel, but no “Unmark” button. To cancel a marked face, you can use any of the following methods.
Method 1: Click Mark without selecting face. After that, confirm that the marked face was canceled by clicking the Draw button.
Method 2: Select a new face and press the Mark button. The previous selection is automatically canceled and a new face is marked.
Method 3: Execute the following command with the TUI (Text User Interface) and confirm that it was canceled with the Draw button. /boundary/clear-marked-faces
- Skewness in ANSYS Meshing
