Tagged: 14.5, fluent, fluid-dynamics, LES/DES/SAS, turbulence
June 5, 2023 at 7:06 am
FAQ
ParticipantPlease turn on the Dynamic Stress from LES Model Options after you select the Smagorinsky-Lily model from Subgrid Scale Model options. This will turn on the Dynamic Smagorinsky Model. In R18.1, you can directly select Smagorinsky-Lily model directly under subgrid-scale model once you select LES model.
- Skewness in ANSYS Meshing
