How to turn on attribute and named selection import options by SpaceClaim script and set the text keys found in “File > SpaceClaim Options > File Options > Workbench”?
- SpaceClaim Options > File Options > Workbench”?" target="_blank" rel="nofollow" title="LinkedIn">
- SpaceClaim Options > File Options > Workbench”?" target="_blank" rel="nofollow" title="whatsapp">
- SpaceClaim Options > File Options > Workbench”?" target="_blank" rel="nofollow" title="reddit">
- SpaceClaim Options > File Options > Workbench”?" target="_blank" rel="nofollow" title="facebook">
April 13, 2023 at 7:32 am
SolutionParticipantPlease refer to attachment to access the solution. Keywords: script, named selection, workbench, attributes
1. 2062406.pdf
- Skewness in ANSYS Meshing
