Tagged: 2019 R1, fluent, fluent-post-processing, fluid-dynamics, General
April 13, 2023 at 7:33 am
SolutionParticipantThere are only two ways to do it: 1. export/import a settings file (will work if bc names are identical) 2. make a journal during creating the iso-surface in case1 and read the journal in case2 (Please refer to attachment for details)
1. IsoSurfacesTransfer.pdf
- Skewness in ANSYS Meshing
