How to transfer distribution of a flow variable (or a combination of flow variables) from one solution to another for the same geometry without affecting data in the 2nd solution?
Tagged: 18, fluent, fluid-dynamics, Scripting/Journaling/UDF, Species/Reactions
June 5, 2023 at 7:06 am
FAQParticipantYou can transfer distribution of a flow variable from one solution to another for same geometry with following steps: 1. Copy required data in a UDS 2. Write interpolation file with UDS data only 3. Interpolate UDS onto the 2nd case/data 4. Define CFF 5. Copy into UDM for further manipulation using CFF in patch initialization, if needed Keywords: UDS, UDM, interpolate
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
