How to to use SHELL93 instead of SHELL181 (automatically selected) in Workbench. Is there a way to select the element type manually in Workbench?
June 5, 2023 at 7:04 am
FAQParticipantYes, you one may manually input the element type using command snippet. Insert command object under the geometry in Mechanical. Insert following commands to change its element type: et, matid, 93 r, matid, 0.1 !! For defining thickness. Note that SHELL93 is out of date and not supported. Also while using legacy elements like SHELL93, it is necessary to define real constants properly.
- ANSYS Mechanical: Node Merge
- Is there a way to show the element coordinate systems so that I know what direction the bending moments are in?
- How to use ANSYS Workbench Meshing Virtual Topology
- I am getting an error that mixed order mesh elements are not supported. How to overcome this issue?
- ANSYS Mechanical: Node Move
- How to use ANSYS Workbench for Shell Meshing and Editing
- How can you identify the element types used by Mechanical?
- How can we apply different loading conditions on both the top and bottom of a shell/surface body, e.g., temperature on top face and convection on bottom face.
- How to change begin node and element number for meshing in Workbench Mechanical?
- What is the difference between shell 63 and shell 181?
