Tagged: 19.1, mechanical, static, structural-and-thermal, structural-mechanics, thermal
March 17, 2023 at 1:11 pm
SolutionParticipantPossible through “Symmetry” tab and control visualization using BETA options.
1. 2058204.zip
2. Solution_ 2058204.pdf
- Does ECAD trace mapping support more than one type of trace material (usually copper) in the same layer?
