How to switch off variable time stepping using TUI? Getting following error. Error: received a fatal signal (Segmentation fault); Variable time stepping is available only for the VOF and Eulerian Multiphase model. Changing the time stepping method to Fixed.
Tagged: 18.1, fluent, fluid-dynamics, General, General - FLUENT
June 5, 2023 at 7:06 am
FAQParticipantVariable time stepping is available only for the VOF and Eulerian Multiphase model. The following errors can occur if it is not switched off for non-VOF and Eulerian Multiphase problems. Error: received a fatal signal (Segmentation fault); Variable time stepping is available only for the VOF and Eulerian Multiphase model. Changing the time stepping method to Fixed. To do this please use following command. /solve/set adaptive-time-stepping no
- Skewness in ANSYS Meshing
