Tagged: 2020 R1, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantYou can use following commands to write files in .cas/.dat format. / file cff-files? No / file write-case-data This will make .h5 format off and then it will write files in .cas/.dat format.
- Skewness in ANSYS Meshing
