June 6, 2022 at 8:33 am
FAQParticipantPlease right-click on Fluent solution cell in Workbench project schematic and go to Properties. There you will find an option called “Data Interpolation” that has a checkbox that’s turned on by default. Please turn it off if you don’t want to save the interpolation file. Note that once you turn off this checkbox Fluent will remove the existing .ip file.
- Skewness in ANSYS Meshing
