Tagged: fluent, fluid-dynamics, stopping criteria, unsteady
June 6, 2022 at 8:45 am
Watch & LearnParticipantThis video shows the steps to stop an unsteady solution when the value of a certain variable reaches or exceeds the desired threshold. This can be useful to define a custom stopping criteria for an unsteady simulation when you are interested in one particular time instant for which the experimental data may be available in order to compare the results.
- Skewness in ANSYS Meshing
