How to split a target surface after creating a weld surface from an edge that is above the target surface?
August 25, 2023 at 12:15 pm
SolutionParticipantYou can usually use the Imprint feature to imprint the weld face edges onto the target surface. Please see attached video for the same.
1. 2049334.zip
- Skewness in ANSYS Meshing
