Tagged: components, Conditions, direction, discovery, Explore, external-flow, Inlet, refine, velocity
February 19, 2025 at 7:10 am
SolutionParticipantExtending to the Inlet flow conditions in Ansys Discovery 2025 R1 we have added a new option to specify velocity inlet components. This new option provides additional controls for defining the inlet flow direction.
This will be helpful in instances where you have flow which is entering the domain not normal to the inlet, for example something like wind loading, which comes in with some velocity.
This option will let you specify the velocity in X, Y, and Z components as shown with this external flow model over a house:
- In-Depth – Fluids Simulation using Ansys Discovery
- Discovery: Porous media coefficient calculator
- Symmetry Boundary condition for Fluid flow simulation in Ansys Discovery
- Discovery – Defining new material
- Ansys Discovery: Topology Optimization
- Discovery Quick Tip- Understanding Contour Settings
- How to apply bolt Pretension in ANSYS Discovery?
- Discovery Quick Tip- How to Export to Fluent
- Discovery Quick Tip- Applying Thermal Conductance
- Structural Simulation using Bolt Idealization
