June 6, 2022 at 10:33 am
FAQParticipantFor wrapping, it is necessary to select which region to wrap after initialization. If more than one area is created, they will be created with names such as “region.1”, “region.2”, etc., but it is difficult to know which region will have which number in advance. The following command automatically selects an area containing an arbitrary coordinate point and executes wrapping. /boundary/wrap/region/wrap-enclosing-region x y z yes * Where x, y, z are arbitrary coordinate values. Using this command makes it unnecessary to worry about the number of the area, which is useful when automating wrapping work with journal files.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- ANSYS ICEM CFD: Basic Blocking
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is the difference between patch dependent meshing and patch independent meshing?
