January 25, 2023 at 7:28 am
FAQParticipantA Flexlm Options File allows you to limit or restrict licenses to specific users. The options file is specified in the ANSYS License Manager through the license file. The license file is modified to add the path of the option file in the VENDOR line as below. VENDOR ansyslmd options=C:Program FilesANSYS IncShared FilesLicensingansyslmd.opt More information can be found in the FlexNet Licensing Guide accessible through the ANSYS License Management Center in the Help Section of the lateral panel.
