How to solve the issue with the error message: The parameter ‘Maximum Number of Loops’ is too small. Please increase its value to at least …
Tagged: 2021 R1, cfx, fluid-dynamics, General - CFX, GGI interfaces
March 17, 2023 at 8:57 am
FAQParticipantThis error message indicates that there is a very large number of GGI interfaces present in the setup. The solution is to increase the mentioned parameter. This can be achieved with the following CCL: SIMULATION CONTROL: EXECUTION CONTROL: CCLSETUP STEP CONTROL: Maximum Number of Loops = 500 END END END The value 500 should be replaced with the value that is provided in the error message or a somewhat higher value.
- Skewness in ANSYS Meshing
