March 17, 2023 at 8:59 am
FAQParticipantFor using radiation only in solids, you can use DO model in Fluent. In your model you will need to define cell zone as solid. Then you will need to enable Energy equation under Setting Up Physics > Models. Then in Radiation, please select DO model. Under boundary condition of solid walls, please select semi-transparent under BC Type in Radiation tab. Give other inputs. In Solving tab, go to Controls > Equations and deselect Flow so that flow equations are not solved. Keywords: DO, Radiation, Solids, Fluent
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- Setting Operating Density for Natural Convection cases when density is modelled using Ideal gas law
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- In Fluent, how can we reduce the time for an unsteady simulation of a Conjugate Heat Transfer (CHT) simulation? Is there any way to give different time steps for fluid and solid in a single simulation?
