General
General
How to slice a plane using a line?
    • FAQFAQ
      Participant
      There is no way to directly slice a plane using a line. So the best approach would be to extrude the line in two normal directions to create two planes whose intersection would be this line. You can then use these new planes to slice the desired plane. Keywords: plane intersection
