January 25, 2023 at 7:34 am
FAQParticipantOne may use “Elastic Foundation Stiffness” (EFS) or “Elastic Support” provided in Mechanical To apply Elastic Support, right-mouse-click the analysis branch from tree outline, say “Static Structural Analysis”, and then choose “Insert”, and choose “Elastic Support”. In the details, scope to the area you want to apply Elastic Support and specify a value for foundation stiffness.
