General
General
How to show the cell partition in ANSYS Fluent?
    • FAQFAQ
      Participant
      In Fluent 18.2 the field variable “Cell Info…” > “Cell Partition” is replaced by “Active Cell Partition” and “Stored Cell Partition”. Similarly, the TUI (text user interface) command /parallel/partition/print-partitions is replaced by /parallel/partition/print-active-partitions /parallel/partition/print-stored-partitions Now, these variables and commands are also available with the serial version of Fluent which was not the case in earlier versions of Fluent.
