Tagged: 18.2, fluent, fluid-dynamics, General, General - FLUENT
March 17, 2023 at 1:10 pm
SolutionParticipantIn some applications like jet milling and flow separation equipment, simulation setup may demand a peripheral swirling inlet from a cylindrical surface. The attached solution explains the setup of the in-built boundary conditions (mass-flow-inlet or velocity-inlet) in such a scenario.
1. 2053479.pdf
2. 2053479.zip
- Skewness in ANSYS Meshing
