June 5, 2023 at 7:06 am
FAQParticipantThe Fluent Text User Interface (TUI) command for transient calculations was extended to allow this command to be added to a journal file /solve/dual-time-iterate 10 20 y 20 In the above command, Fluent will calculate 10 time steps with a maximum of 20 iterations each and then do 20 pollutant iterations. Alternatively, you can define it step by step: /solve> dual-time-iterate Number of physical time steps [3] 10 Number of iterations per time step [11] 20 Postprocess pollutant solution? [yes] yes Number of post-processing iterations per time step [20]
- How do I model humidity in Fluent?
- Configuring and Solving the Chemical Species Transport in Fluent
- ANSYS Fluent: Describing Non-premixed Combustion using the Steady Flamelet Model
- ANSYS Internal Combustion Engine (ICE): Port Flow Part 1 – Getting Started
- Model setup: Setting up chemical reactions
- How do I use the Flamelet Generated Model?
- How can volume fraction be plotted in a species transport simulation?
- ANSYS Chemkin-Pro: Reducing a Combustion Mechanism
- I am running an electrochemistry simulation in Fluent. How can I access the electrochemistry reaction rates with UDF?
- Explanations on the warning Maximum / Minimum PDF table enthalpy exceeded in xxx cells (Non-Premixed or Partially-Premixed models)
