June 6, 2022 at 8:33 am
FAQParticipantYou can set a CEL expression for the heat source such as: HeatIn = HCoef * (Treq – T) where Treq is the required temperature and HCoef is a positive valued power density coefficient (units = [W m^-3 K^-1]). The size of HCoef determines how fast your heat source reacts to temperature changes. You want HCoef to be large enough to give you the behaviour you want but not so large that it makes the solver struggle. Setting the source coefficient to be -HCoef should help significantly with convergence.
- Defining heat transfer coefficient (HTC)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- Thermal Analysis of a Radiator Using Ansys Fluent
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to add comments to journal file so that I will know what each entry does?
- How do I get rid of convergence problems with energy equation in Fluent (especially since R15)?
