February 6, 2023 at 2:42 pm
FAQParticipantBackground: In Icepak there is only a 2D heat exchanger object available. On the other hand the thermal specification for the 3D Resistance object is limited to constant or spatial distributed (predefined) power. Solution: A combination of 3D Resitance and 2D Heat Exchanger objects is possible. The 3D Resistance (no thermal specification) gives maximum control of the pressure losses in different directions. A number of Heat Exchanger objects (no pressure loss specification), placed in the 3D Resistance zone, allows heat exchange controlled by the temperature difference between local Fluid and external (cooling/heating) Fluid. Obviously, the number of Heat Exchanger objects in the Resistance zone will define the temperature and heat exchange resolution.
- ANSYS Icepak: Computing Metal Fraction and Thermal Conductivity of a Trace
- ANSYS SpaceClaim: How to change autosave interval
- ANSYS Icepak: How to open an Icepak tzr or an existing Icepak project in Workbench?
- ANSYS Icepak: Importing Geometry Using Libraries
- Quick Guide to HFSS Icepak Coupling
- ANSYS Icepak: Post-Processing Enhancements – Part 1
- ANSYS Icepak: Changing Materials For a PCB
- Creating Icepak-Compatible Objects in SpaceClaim
- Electrothermal Design of Power Converters for Electric Propulsion Systems – II
- Electrothermal Design of Power Converters for Electric Propulsion Systems – III
