Tagged: 16, fluent, fluid-dynamics, General, General - FLUENT
January 25, 2023 at 7:16 am
FAQParticipantThis can be set using the process affinity command as shown below: (set-affinity “0 4 1 5 2 6 3 7”) The inputs needed are pairs of process id and a cpu/core id. In the above example, the process ids are 0-3 and the core ids are 4-7. The process ids for nodes start at 0 and is set to 999999 for the host process.
- Skewness in ANSYS Meshing
