March 17, 2023 at 1:10 pm
SolutionParticipantThe compression for the HDF5 ( *.cas.h5 & *.dat.h5 ) file formats needs to be defined prior to writing the files. It can be done from Fluent using the following TUI command: /file/hdfio-options/compression-level 3
1. FAQ_2055156.pdf
- Skewness in ANSYS Meshing
