May 25, 2023 at 7:30 am
SolutionParticipantThe geometry is the collection of all the objects drawn in the 3D Modeler. Since non-model objects are drawn in the geometry they affect what is visibly seen or included in the modeler. They, however, do not affect the simulation as they are ignored by the mesher. The S-parameter results and far-field patters are not affected by non-model objects either. Users can use non-model object to see what would happen to the result should the object be removed without having to physically delete the object from the model. They can also be used for post-processing purposes like plotting a field quantity along a line or a field overlay over a surface. To employ this feature, the user should follow the steps below. Select the object, then Draw > HFSS 3D Layout Properties > Add Modeling Under Modeling Props > uncheck “Modeled”
1. How%20to%20set%20non-model%20property%20to%20an%20object%20in%203D%20Layout.pdf
- I got “I/O error when reading design” error message when opening an AEDT project with HFSS 3D Layout designs after a system crash. How should I proceed to recover my project?
- How to Export S-Parameters from HFSS 3D Layout/HFSS 3D Designs ?
- ANSYS HFSS: Creating 3D Components
- Error: Extracta view creation failed; extracta run failed: Create process failed with error 2: Could not find application extracta.exe.
- How to Set “Non-Model” Property to an Object in 3D Layout
- How to export a design from HFSS 3D Layout to HFSS 3D Classic?
- ANSYS HFSS: 3D Layout Cut Out Sub-design – Simulation and Post Processing
- ANSYS HFSS: 3D Layout Model from a Cadence Board File
- How to Create Bondwires in 3D Layout ?
