March 17, 2023 at 1:11 pm
Solution
ParticipantThe number of faces per surface cluster can be given using the following TUI: /def/mod/radiation s2s-para set-vf-para , 10 , , , , , , q q Here, 10 is the manual input for faces per cluster, with others as default. Other parameters related to view factors can also defined under the s2s-para section, please refer to the image attached herewith
1. view_factor_TUI.tif
- Defining heat transfer coefficient (HTC)
- Thermal Analysis of a Radiator Using Ansys Fluent
- Simulating Battery Pack Cooling System Using Ansys Fluent
- How to solve the warning: “Warning: zone of type interior found between different solids!”
- How to add comments to journal file so that I will know what each entry does?
- In ANSYS Fluent, when the energy equation is enabled and viscous heating is enabled, must pressure work also be turned on?
- ANSYS Fluent: Overview of the Mapped Interface Technique for CHT Simulations (18.2)
- How to use Thin Walls with Thermal boundary conditions?
- ANSYS Fluent Student: Conjugate Heat Transfer in a Heat Sink
- What is the difference between internal and external emissivity?
