Tagged: 2019 R3, fluent, fluid-dynamics, General - FLUENT, workbench
April 13, 2023 at 7:33 am
SolutionParticipantThis Solution shows on how to use lbm/min as a massflow boundary condition value, instead of kg/s. The same can be applied for any other b.c. values. Please see the attached PDF for a detailed description. Keyword: units, expression, SI, lbm, minute, input parameter, parameter set, DP, Fluent
1. 2061180.pdf
- Skewness in ANSYS Meshing
