March 17, 2023 at 8:58 am
FAQParticipantYou can use the power select tool. Click on one of the faces, go to Selection, if your geometry has multiple bodies and the faces with same area are across multiple bodies, check the Search All Bodies option and select Faces with same area. This selects faces of same area. Now click on Create NS to create named selection and this applies one single named selection to all the selected faces.
- Skewness in ANSYS Meshing
