March 17, 2023 at 8:58 am
FAQParticipantYou can select one or more objects quickly by using the Select tool. Click the first face of your design, hold down the Ctrl key, and then click each individual selection you want to add to or remove from your original selection.
- Skewness in ANSYS Meshing
