June 6, 2022 at 10:33 am FAQParticipant FAQParticipantTo retain mesh on unchanged parts, on Workbench page first go to Tools –> Options–> Geometry Import–> Compare Parts on Update and set it as “Associatively”. Then add the new bodies to geometry and update the model in Meshing session. If newly added bodies are in separate parts, then the existing mesh will be fully preserved. If new bodies are added within existing part, all these new bodies and the old bodies which are connected to the new bodies will need to be meshed. Remaining all bodies will have their mesh preserved.
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- ANSYS ICEM CFD: Basic Blocking
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- How can I create a 2D section from a 3D model in SpaceClaim ?
- How do you turn a rectangular surface mesh into a triangular surface mesh?
- What is the difference between patch dependent meshing and patch independent meshing?
 You are navigating away from the AIS Discovery experience
