Tagged: 2020 R1, fluent, fluent-post-processing, fluid-dynamics, post-processing
March 17, 2023 at 1:10 pm
SolutionParticipantTo automate the post-processing in Fluent at the end of the calculation, it is possible to add command lines (for example to save a Report File). It is done thanks to the Calculation Activity menu. Please see the attached document.
1. 2063043.pdf
- Skewness in ANSYS Meshing
