Tagged: 18.2, fluent, fluent-post-processing, fluid-dynamics, post-processing
June 5, 2023 at 7:06 am
FAQParticipantIf you launch Fluent from C:Directory (where case/data files are) and wants to save pictures to C:DirectoryPictures with the /display/save-picture command, then you should be able to use sync-chdir ./Pictures /display/save-picture name.jpg
- Skewness in ANSYS Meshing
