March 17, 2023 at 9:01 am
FAQ
ParticipantThe command to run the Product & CAD Configuration Manager in batch mode on Windows is: “
commonfilesCADbinwinx64Ans.CadInt.CADConfigurationUtility.exe” -arguments Example: “C:Program FilesAnsys Incv194commonfilesCADbinwinx64Ans.CadInt.CADConfigurationUtility.exe” -ug_plugin For NX interface, the user can specify either the -ug or the -ug_plugin option. If they; 1) have NX installed 2) have UGII env var’s (given below) set and 3) want the associative interface installed/configured. Using the -ug will install the associative interface if NX and the env var’s are set otherwise it will install the reader. # To allow non-administrative users to run, you will need to define the environment variable UGII_CUSTOM_DIRECTORY_FILE prior to running the command and specify a location where other users have read access. Alternatively, you can run the Product & CAD Configuration Manager after the installation and provide an updated location for the NX Custom Directory File Path under the NX tab. # UGII Environment Variables: UGII_BASE_DIR to Full path to NX installation UGII_CUSTOM_DIRECTORY_FILE to %APPDATA%ANSYSv194Unigraphicscustom_dirs.dat UGII_ROOT_DIR environment variable must be set to the ugii subdirectory in the install path of the NX version to be launched. Do check the Support version of NX for the respective ANSYS released version.
- Q: How do I set the license server from my client machine?
