April 5, 2023 at 2:33 pm
FAQParticipantBatch mode is EnSight is based on command language or Python scripts. To run EnSight in batch mode using a Python script, please use the following command: ensight102 -batch -p file.py ‘file.py’ is the python script you are trying to run. You can find a list of all the flags you can use in the EnSight ‘how to’ manual. Please search for ‘How to command line start-up options’ for this. Please also look up ‘How to use batch’. You can assess this manual from ‘Help’ menu on EnSight.
- Skewness in ANSYS Meshing
