Tagged: 18.1, fluent, fluid-dynamics, General, General - FLUENT, gpu, hpc, parallel, scripting
March 17, 2023 at 1:10 pmSolutionParticipant
We can use python scripts to run automatic HPC benchmarks. An example is in attachment. In this script, we define the working directory (path), the case file, the number of core to test and the number of gpu to test. path=”E://” setupfile=”E:/cube.cas” core_list=[1,2,4] gpu_list=[0,1] The results are saved in a text file in the working directory: #Cores then #GPUs then Time. The script can be launched with: “%AWP_ROOT181%FrameworkbinWin64RunWB2.exe” -B -R “E:\2049450.py”
1. 2049450.zip
- Skewness in ANSYS Meshing
- How can I select interior faces and other entities that are inside the model?
- Error: Update failed for the Mesh component in Fluid Flow (Fluent). Error updating cell Mesh in system Fluid Flow (Fluent). View the messages in the Meshing editor for more details.
