March 17, 2023 at 8:58 am
FAQParticipantIf the script editor is open, SCDM updates the graphics without option to suppress/suspend it. When the editor is closed, the graphics will not update line-by-line, only after finishing the script. The script cab be published as a group. From the group panel, we can run the script without opening the editor.
- Skewness in ANSYS Meshing
