June 6, 2022 at 10:33 am
FAQParticipantGo to ‘Measure’ tab, then select ‘Normal’ tool. Now select all the surface bodies, it will highlight the surface normal for each of it. Select surfaces whose normal should be changes. Select ‘Normal’ tool. Right click in GUI window and select option ‘ Reverse Face Normal’
- Create Sections in Meshing
- Tip on exporting geometry in Parasolid, STEP format from DesignModeler
- How to reverse surface normal in SpaceClaim?
- How to Change the Direction of the Normal Vector of the Internal Face?
- ANSYS Fluent: Watertight Geometry Meshing Workflow
- ANSYS Workbench: Decomposition and Hex Meshing – Part I
- ANSYS ICEM CFD: Basic Blocking
- How can I create a 2D section from a 3D model in SpaceClaim ?
- What is the difference between patch dependent meshing and patch independent meshing?
- Fluent: Watertight Geometry Meshing Workflow
